Administrators Jannza Posted June 27, 2010 Administrators Report Share Posted June 27, 2010 My current bike setup is Shimano Tiagra 9 speed. 30 / 39 / 50 with a 12-25 cassette. Would it make much difference changing to an 11-25 as when I build up speed on the flat I run out of gears? Is it possible to change this without spending a fortune I do need to keep the 30 x 25 or higher to be able to get myself up the clune! The bike needs serviced and one of the cables replaced so if its not to complicated/expensive I'll get it done at the same time. Thanks Quote Link to comment Share on other sites More sharing options...
KennyS Posted June 28, 2010 Report Share Posted June 28, 2010 Jann, I may have a 40 or 42 tooth middle ring lying around. You're welcome to it FOC if I can find it. You may find it a bit heavier going though if you are using the middle ring most of the time. A 10 min job to change over I'll have a look and see if I can dig it out Kenny Quote Link to comment Share on other sites More sharing options...
Administrators Jannza Posted June 28, 2010 Author Administrators Report Share Posted June 28, 2010 Hi Kenny That would be good to try. I've seen a 30 / 42 / 52 at a good price but has 5mm longer cranks than my current setup. Quote Link to comment Share on other sites More sharing options...
2023 Subscriptions ginty001 Posted June 28, 2010 2023 Subscriptions Report Share Posted June 28, 2010 Jan, SRAM do a 9 speed cassette with 11-26, which would give you an extra tooth at each end. http://www.chainreactioncycles.com/Mode ... elID=17902 Ian..... Quote Link to comment Share on other sites More sharing options...
Hertz Van Rental Posted June 28, 2010 Report Share Posted June 28, 2010 30 x 25? I've climbed the Clune on a 53 x 16! Quote Link to comment Share on other sites More sharing options...
Administrators Jannza Posted June 28, 2010 Author Administrators Report Share Posted June 28, 2010 30 x 25? I've climbed the Clune on a 53 x 16! You must have longer/stronger legs than me! Quote Link to comment Share on other sites More sharing options...
Hertz Van Rental Posted June 29, 2010 Report Share Posted June 29, 2010 Twas a few years ago and not a pleasant site - especially the first bit. This then turned into a bit of a challenge to see who could do the whole climb in the biggest gear. I suspect Donald Scally may have managed it in a 15? Quote Link to comment Share on other sites More sharing options...
KennyS Posted June 30, 2010 Report Share Posted June 30, 2010 Twas a few years ago and not a pleasant site - especially the first bit. This then turned into a bit of a challenge to see who could do the whole climb in the biggest gear. I suspect Donald Scally may have managed it when he was 15? Fixed it for you Gordon Quote Link to comment Share on other sites More sharing options...
Hertz Van Rental Posted June 30, 2010 Report Share Posted June 30, 2010 Nothing to fix Kenny - I should have said that I meant a 53 x 15T cog - not 15 years old. Quote Link to comment Share on other sites More sharing options...
Administrators Jannza Posted June 30, 2010 Author Administrators Report Share Posted June 30, 2010 Let's bring this back then, I'm available to supervise! Quote Link to comment Share on other sites More sharing options...
Hertz Van Rental Posted June 30, 2010 Report Share Posted June 30, 2010 Actually wouldn't be a bad event; a) Fixed wheel / single freewheels only Winner is the one who covers the hill in the biggest measured gear c) no stopping allowed (apart from traffic at roundabout) d) placings decided by gearing sizes. Those who DNF still get a placing depending on how much they managed (just like long jump, throwing events etc) e) where two riders tie - heavier bike wins Quote Link to comment Share on other sites More sharing options...
Colin H Posted June 30, 2010 Report Share Posted June 30, 2010 f) Heaviest rider award Quote Link to comment Share on other sites More sharing options...
