DavieB Posted March 24, 2018 Report Share Posted March 24, 2018 So I decided to fit it today couldn't find the instructions and cabled up in what I considered to be the most logical fashion......however later did find the right manual on web and have following query.. The 3 port junction box (A) which is suspended off the stem has ports arranged in an inverted triangle - two at top one at the bottom. Following logic I assembled with the cables routed from the shifters going into the top two ports thus achieving symmetry and used the single (bottom) port to run the longer cable to the inner frame. However the manual appears to show a different routing arrangement with the LH shifter entering the leftmost port and the RH shifter plugged into the bottom port so they are effectively running sequentially from left to right so to speak - anybody know which one is right? Also the inner frame junction box (4 port) it would appear from the manual that it is immaterial which cable goes where - again is this correct? Can't try anything unfortunately as the build has been postponed for the sake of a compatible braze on adapter ....drat! Cheers, Davie Quote Link to comment Share on other sites More sharing options...
2023 Subscriptions XXX Posted March 24, 2018 2023 Subscriptions Report Share Posted March 24, 2018 It doesn’t matter I have left in left right in right and the other in the middle on TT bike works perfectly Quote Link to comment Share on other sites More sharing options...
2023 Subscriptions P McDonald Posted March 25, 2018 2023 Subscriptions Report Share Posted March 25, 2018 Billy is right but don’t ask him about quick release on wheels for sure the front A junction can take any cable any port, they must be coded Quote Link to comment Share on other sites More sharing options...
DavieB Posted March 25, 2018 Author Report Share Posted March 25, 2018 Cheers ...should get it charged and operational during the week. Quote Link to comment Share on other sites More sharing options...
