Parts clear-out
  • Members
Prices are based on completed eBay auctions or my best guess. Happy to negotiate. I'll leave this thread here so you can all have a look, then I'll take my wares elsewhere. Thanks for reading, folks.
Specialized Allez frameset - Price-drop to £45
- Seat tube: 54cm (c-t)
- Top tube (actual: 55.5cm; virtual: 57cm)
- Aluminium frame; carbon forks
- Scuffs and touched up chips. Paint flaking from underside of metal fork crown
- New derailleur hanger; new headset bearings
- Would build into a decent training/winter bike
San Marco Rolls saddle - sold
- Very little use
- Good condition
Campagnolo Nuovo Record derailleur - sold
- Good used condition
- Marked "Pat. 81"
- Original jockey wheels
Campagnolo front mech - sold
- 28.5mm clamp
- Good used condition. Signs of wear on the inside of the chain cage
- This came from the same bike as the derailleur. I assume they're a matching pair
Campagnolo downtube shifters - sold
- Shifters in very good condition
- Marked "Brev. Inter. Campagnolo"
- Signs of fatigue on the metal band which attaches the levers to the downtube. Some life in it yet, though
Campagnolo hubs - sold
- Front and rear, with 5-speed cassette.
- 120/110mm spacing
- Decent cosmetic condition. They feel like they could do with a change of bearings, though
Campagnolo quick release skewers - sold
Specialized road bars - £12
- 44cm wide
- 26.0mm diameter
Shimano BB-UN26 sealed cartridge bottom bracket - £6
- 113mm axle
- For 68mm BB shells; British threading
- Less than 50 miles use
YST threadless bottom bracket - £10
- Never mounted
- For 68mm BB shells with stripped threads
- 120mm axle
Specialized MTB grips - sold
- Excellent condition
Cut-down MTB bars - £5
- 54cm wide
- 25.4mm centre
Shimano M520 pedals - sold
Bluemels Club Special full mudguards - sold
Ambrosio Campione del Mondo track bars - sold
- 38cm wide
- Scored where some eejit's attached a brake. You won't see it through bartape, though
- Light scratches around the centre of the bar
  • Members
Yes, Martin and Jann, you can have first refusal. I think you should have a look at the pedals in person first. Both pairs are in good working condition; the bearings are excellent, but cosmetically they're pretty sketchy. That doesn't really come over in the photo. I've got new cleats if you need them. You'll probably have to wait till the Don Smith to inspect them - I'll be starting from Bishopton this Sunday because of a midnight finish the day before.
  • Members
Yes to the bars, Kenny.
Mark, I'd love to sell you the frame, but it's miles too big for you. Sorry. To ride it, prospective owners need to be a minimum of six-feet tall, I'd say. For a really good fit, you'd need to be a wee bit bigger than me - 6'1", 6'2", something like that.
  • 2 weeks later...
  • 3 years later...
  • Members
Old thread resurrected. Drowning in a sea of bike parts.
Miche Primato Advanced 49t chainring - sold
- Brand-new. Never used; never mounted.
- 144 BCD
- Would consider a swap for an identical 48t Miche chainring in as-new condition.
Fuji track cranks - on my new Planet X
- Very good condition. Decals are perfect. Faintest shoe rub, but you have to tilt the cranks in the light to see it.
- 170mm. 144 BCD.
- Supplied with stack bolts and crank bolts.
- These have only seen velodrome use.
Selle San Marco Ponza saddle - £9
- Slight rubbing to Ponza decal. 1.5cm x 3mm scrape on rear right-handside, of the sort produced by sliding down the banking. That said, white bits of saddle are still very white and the underside and rails are in excellent condition. This has only seen velodrome use, too.
Selle Italia Tri Matic saddle - £7
- Used condition. This one has been outside. Top of saddle in good condition with a little rubbing to the decals. Underside less so: rubbing to the rails and a bit of rust on the staples.
Bike Box Alan saddle pack - £9
- Brand-new. Never used.
  • 11 months later...
  • Members
Specialized Comp Multistem - £18
- 100mm; 24 degrees; black in colour.
- For 31.8mm oversized bars.
- Comes with three shims to allow adjustment of stem angle.
- Used to set up my position on a new bike. It hasn't been ridden outside.
Deda quill stem adapter - £9
​- Allows you to fit a 1" threadless stem to a 1" threaded steerer tube.
- Brand new.
Photos on request.
  • 1 month later...
  • Members
Photo of Specialized Comp Multistem, as detailed above, plus:
Cinelli Pista track stem - £10
- 130mm, 65 degrees.
- Used to set up position on new frame. Brand-new.
Titanium in-line seatpost - £25 - sold
- 27.2mm diameter.
- 31cm of post.
- Very good condition, but the clamp is a pain in the backside to adjust and it made the last saddle I used it with squeak, hence the low asking price.
Fuji carbon track forks - £40 - sold
- 1 1/8" alloy steerer.
- Uncut (23cm of tube.)
- Drilled for a front brake.
- From a 2009 Fuji Track Comp.
- Velodrome use only. Very good condition.
  • 1 year later...
  • Members
Zipp Vuka Alumina aero extensions - £22
- 22.2mm outside diameter; compatible with a wide variety of clamps.
- 360mm long.
- Gloss black finish.
- Faint marks from clamp but otherwise brand-new.
TRP RL970 carbon aero brake lever - £17
- Left-hand lever only.
- Detachable shim for compatibility with a wide variety of base bars.
- Perfect for aspiring left-handed fixed wheel time triallists. :-)
